DJI WooKong-M Firmware 5.18,Software 1.36 & Manual 3.6
- Jean-jacques & Co
Bonsoir, le firmware de la wookong M de chez DJI arrive en version 5.18 shut
avec limitation en altitude et distance pour se mettre à la réglementation française ....
http://www.dji-innovations.com/products ... downloads/ :
@Wookong-M Firmware* v5.18 du 2013-01-30 et Wookong-M User Manual v3.6 du 2013-01-30
UN extrait du manuel qui va bien :
"Height Limit"
If height restriction is needed, please turn to the “Tool” tab of the assistant software. Click ON and write a
value (Range: 20~300m) to the Max Height box, so that the aircraft flight height will not higher than the
max-height in any control mode (Manual/ATTI./GPS ATTI. Mode). However, the fail-safe and the Ground
Station operation are not restricted to this height limit. If no height limit is needed, please click OFF.
"Distance Limit"
If distance restriction is needed, please turn to the “Tool” tab of the assistant software. Click ON and write a
value (Range: 30~500m) in the Max Radius box, so that the distance from the aircraft to the Home-point will
not be longer than the max-radius you set. The Distance Restriction function ONLY works in GPS ATTI. Mode.
The aircraft may fly out of the restriction when emergency brake is carried out at the border (the buffer zone is
about 10m), if it flies out of the restricted distance the Control Mode LED will blink Cyan. However, the
fail-safe and the Ground Station operation are not restricted to this distance limit. If no distance limit is
However, the fail-safe and the Ground Station operation are not restricted to this distance limit. If no distance
limit is needed, please click OFF. bravo
A voir et à revoir .... shut
"Height Limit"
"Distance Limit"
La théorie, c'est quand on sait tout et que rien ne fonctionne.
La pratique, c'est quand tout fonctionne et que personne ne sait pourquoi.
Ici, nous avons réuni théorie et pratique : Rien ne fonctionne... et personne ne sait pourquoi !
- rasemotte
Re: DJI WooKong-M Firmware 5.18,Software 1.36 & Manual 3.6
Oui mais... va voir ici.
http://www.mk-fr.info/forum/index.php?topic=11324.0
C' est pas encore ça d' après ce qu'ils disent. Comme tu dis shut , à suivre.
A+
il est clair que l'on est encore loin de ce que demande la france ! la suite n'est pas pour maintenant , le marché pour quelques pro francais n'est pas assez rentable pour DJI surtout que la plupart sont équipé MK ... zen
- Jean-jacques & Co
sur le site : http://www.developpement-durable.gouv.f ... r-des.html nous trouvons la liste des constructeurs français de drône homologué.
"Liste des constructeurs de drones ayant reçu une attestation de conception de type (mise à jour le 15/01/2013)"
sur cette liste figure le nom du constructeur, son adresse et les modèles homologués.
Chez XAMEN technologies à Pau, nous trouvons le modèle BE4000 de catégorie D homologué de série S,S2,S3 ( L'homologation de série dispense de déposer un dossier technique. Seul le map reste à déposer) (3900 € ht
cf http://www.xamen.fr/catalogue_uav_drone_xamen.php#
En regardant les spécifs et la vidéo, nous voyons que c'est le wookong qui est utilisé sur cette machine.
On trouve même l'homologation du modèle dans les données techniques.
Ben alors, je comprends plus grand chose je suis idiot !
il faut que tu lises le forum mk dans le detail , tu verras , les langues se délient , moi aussi je ne comprenais pas , regardes ici : http://www.mk-fr.info/forum/index.php?topic=10880.0
au fur et a mesure que les gens parlent , tu te rend compte qu'il ne sont pas les clous et qu'ils le savent ...
pour ce quadri , l'homologation est en cours ... il faut bien lire toutes les exigences de la DGAC , et la wookong ne rentre pas encore dans ces exigences . ohé !
comme c'est du déclaratif , la dgac ne verifie pas, pour l'instant , mais attention a la commission qui est en train de se former ... shut
- rasemotte
mdr C' est une bonne prise de tête, hein?
c'est sur que c'est plutot emmerdant de donner 1000 euros de plus pour une licence commercial a MK , d'un autre coté , c'est le seul qui a developpé son produit specifiquement pour la france ,alors ... pensif
- rasemotte
pensif je dirais que la différence est grosso modo de 500 euros entre les 2 plates forme pour être dans les clous tout de suite. En fait cette licence commerciale existe depuis longtemps chez MK.
PC vs MAC, DJI vs MK, boxe mais au final tout le monde s' y retrouve.
